Broke one of my plastic plexi thingy T-Top! Help!
Car: 89 Firebird
Engine: 2.8 V6
Hey guys!
My 89 FBird has those dome typed plastic t-top's in her, well I broke the passanger side t-top pretty bad(I read some place that you have to be careful what year's you get the new on from)
What year T-Tops will work in my car? I really want to go with glass even with the fact that its not as light as the plastic(but they look nicer and last longer from what I have seen so far. Any ideals and tip's?
Plexi one's will work if I must but would rather run glass if it will work on my 89.
Donnie H.
Donnie H.
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you have pin type tops, I have a set you can have. You just need to use the weatherstripping you currently have as I used the weatherstripping to overhaul my existing pair. If you have a hook type, I have no clue.
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I had those plastic T-tops for a couple months before they fell apart like that. I just went to the local junkyard and picked up a set that fit... They're bound to have a set that will fit on your car.
Pac J
05-17-2020 10:44 AM
