whats next to do?
whats next to do?
youll be able to see what i have done so far listed below. what do you think i should do next? im gonna be working w/ probably a couple hundred bucks. im thinking igntion stuff, not sure. what do you all think i should go w/ next? any suggestions under... oh $400 are welcome.
1 Post
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Are you trying to go faster?
If so, drop the 10's and the box . Jus kidding. How about a bottle? Best bang for that kinda cash. A good ignition box would be nice too...
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
I have MSD box, and to tell you the truth, its a waste unless running high compression or boost. The coil on the other hand helps alot with throttle response.
I would go with an AFPR and a performance Coil.
Car: 1986 Firebird
Engine: 2.8 V6
Agreed; I saw more from putting a high-voltage coil on than when I added the MSD 6AL box on. But I had done everything else to my ignition; putting an MSD box on was the last thing to do. (Next step will be the Holley ignition module...)
What size shoes are you running? You could go to a slightly shorter rear tire, and that'd increase your effective gear ratio slightly. The lower gear/posi idea is a great one... I miss my 3.73/posi/disc rear... (sigh)
TomP. ive just got stock tire size. IIRC, 235/60/r15. my tires are only have a few thousand on them though.
so what are the best plug wires to run? i was thinking 8 or 8.8 wires, but what brand? how bout cap and rotor brand? i just got a new ignition module about 2 months ago, factory one. if i get a new coil, is it good to relocate it somewhere else?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by Brian K
Tom what happened to your rear?
I never found out but that $450 powertrac they installed on HP TV this weekend was neat. No special tools needed, not a spool replacement but a spider gear replacement. Real easy few hr swap. Makes the car Posi while going straight but still acts like a peg leg when you turn.
They put it in a wagon so it can take some abuse.
