heater core question
Car: '89 Camaro RS
would it be possible to bypass the heater core by connecting the two coolant hoses together? if so would this cause any problems?
Car: 1986 Firebird
Engine: 2.8 V6
Yes you can, and there'd be no problems. Hose sizes will be slightly different though, one is 5/8", other is 3/4". Might as well just loop a new section of 3/4" hose between the water pump fittings.
Do you have an 82-86 or 87-92?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
On my thirdgen and wagon, I ues them plastic flush T connectors they sell in the prestone flush n fill kit or alone off the shelf. [autozone sells just the plastic T fitting and cap] I use the biggest 3/4 one and have no problems getting the 5/8 hose to seal. Just tighten down the clamp well. I have never sprung a leak.
Every summer I do it to both cars.
Matt
Matt
