Chip Chip Chip.... V6 Chip
dang yall.. long time since ive posted on here, if anyone remembers me. Anyway, who's tried which chip for the v6, what about results? worth it? not?
1 Post
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
You ask about buying, then say you are selling? They are all pretty much the same when it comes to over the counter aftermarket chips. They are all a little better than stock- worth it? I would say yes- they give you a noticable difference in throttle response.
If you want that little bit more of an edge, you'll need to find someone local to you that can ride along and scan your engine outputs, then custom burn a chip to your cars modifications.
Edit: I should also mention that there is hardly a noticable performance difference between the custom chip I have and the Hypertech thermochip I was running prior. I noticed much more of a difference between the stock chip to the hypertech chip. My injectors are maxxed out.
Gunner242
12-25-2015 04:49 PM
KO1
16
10-15-2015 05:00 PM
