Super hesitation and bogging problem , need help
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Hey guys my car does this thing where it will idle ok and idle in gear fine but when i push the gas in gear it bogs and hesistates and on occasion it will stall itself. It does this until ive driven for a while then its not as bad. Ive done the TomP tune up but it didnt help .. i have fuel pressure changed the fuel/oil and air filters I havent chaged the o2 sensor just yet cause some idiot welded it in. I changed everything it says to change in the tomP tune up except the ignition coil but im not seeing much if any blue spark when engine is running in the dark so i dont thik its bad. I havent changed the egr either cause thats like 52$ at napa. I did take the injectors out and put them back in w/o changing the oring but i dont have leaks. I just put an new upper plenum and throttle body on w/ nothing
Can anyone help? I need this to stop cause its starting to get scary to drive it when it does this. It does it starting from a stop only
by the way .. i got no code when it stalls .. well code 12 over and over and over again heh but i do have a cone filter coming off the maf with the IAC thing hanging near it
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
From the last 10 post/problems you have had, it may be time to pawn that lemon off on to someone. Almost every day you have a new problem???
Matt
Matt
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
He didn't have the IAT sensor properly located.
edit:
wonder if I fall into that catagory? No, wait, fires don't count
edit:
Matt
Matt
Matt
Matt
someone972
08-30-2015 12:52 AM
