would my v6 2.8 firebird support a turbo charger?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
I own a 89' firebird v6, the engine is in good condition and I would like to know if it supports a turbo charger.
any ideas.
any ideas.
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Welcome to the boards
Before everybody starts screaming at you to use the search or just scroll down the screen, usr the search.
https://www.thirdgen.org/techbb2/sho...hreadid=190835 Read this thread, lots of good inffo and will absolutely answer your question.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
it should, alot of fiero owners have turbo 2.8's running like 6psi of boost on stock bottom ends, which is definatly a noticable improvement.
The Compression ration is really too high too support much more than that, and if you wanted to run any high amount of boost, to at least get forged pistons. The connected rods and crank should hold up to a decent amount of power due to the cranks short stroke.
One person made 400ft/lbs of torque on the stock bottom end of his 3.4.
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
mmmmm, I think I'll install a small turbo.
thanks
thanks
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
1992 Trans Am
05-10-2023 07:19 PM
Terrell351
06-13-2021 01:13 PM
