Alcohol in the gas tank?
I have heard a few things about there being some benefit to putting alcohol into the gas tank.
Does anyone know more on this subject? I don't know anything about it, but I would love to know the pros and cons.
1 Post
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
don't do it. i just put up a post about running an alcohol injection system... alcohol (i'm assuming you do mean the racing fuel ) will not mix with gasonline. i am wondering about spraying it with gas though. but, the alcohol and gas will not mix and you must burn a lot more alcohol to even run than you do gas.
Everything I ever heard was about rubbing alcohol (100%) I don't know about the racing gas or what, I am just curious if anyone here has done it, and why.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
rubbing alcohol is used for dry gas, same thing but cheaper, more, better. BUt as it goes right now 91% is the most I can get in the store anymore. No big deal really. Some gas already has 10% acohol.
Matt
Matt
1 Post
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Alcohol also burns REALLY clean. I just got my Fiances car to pass smog by adding a little racing fuel to the gas. Only about 1 gallon to a 15 gallon tank, that way it doesn't burn too hot and kill the motor. passed with flying colors, now with a new fresh tank of 87 it runs better than before(don't know what else it cleaned out, but what the hell)
