Trouble taking off intake plenum
1 Post
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I can't seem to get it off, i took all 10 bolts off from each side, including the throttle cable bracket and throttle body. It just seems stuck on and I can't see what is holding it down. The reason im taking it off is to give it a polish since its just sitting there after I pulled the transmission to replace the clutch and rear main seal. Can someone give me a hand? Im following the haynes book and did everything it said, it seems stuck on, thanks.
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
Re: Trouble taking off intake plenum
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: Re: Trouble taking off intake plenum
Originally posted by Lee7
did you try using a prybar/large screwdriver to break it loose?
1 Post
Hahaha. Well I tried a large flat head and no avail so I had mr. intake plenum meet mr. rubber mallet and all went well, a few light taps and it came loose. Ok quick question, do I need to replace my gasket now or should I use the old one? If it needs replacing is there somewhere like Hi/Lo or Autozone that would carry it here in town? Thanks for the replies guys.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Call around! Tell them ya need a gasket for the upper intake plenum, that goes between the two halves...they'll probably be able to look it up or something. Worse comes to worse, go in in person with a picture or something and show them what you need.
I assume Discount Auto (Advance Auto Parts in some areas), Autozone, or Pep Boys might carry one. Good chance they might not have it in stock though.
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Check napa. They have a plenum gasket set for about 12.99 i just replaced my intake gaskets last weekend.
search www.napaautomotive.com you'll find it
