2.8-3.1 swap
2.8-3.1 swap
is it worth swaping in a 3.1 or mayby bigger my dad thinks i should het a fwd engine and tranny outa a new montecarlo and put it in the rear somthing like a fero the frame is right there but i whould have to move a whole bunch a crap around but it will good in winter
or get 2 fwd motors 1 in front and 1 in rear just like susuki did in there pikes peak car but thats when im unemployed and have alot of $$$$$$$$ and time
Re: 2.8-3.1 swap
The 3.1 is a stroked 2.8, very little difference. Get a 3.4, add a cam, port and polish the heads, 3 angle valve job, use the 2.8 intake but port it out, have the cylinder honed and replace the pistons and rings, then add a trans-go shift kit to the tranny. You will spend about 6-800 for the motor, have someone do the porting then do the rest with your dad, you will also make more power this way and addind two engines will add a ton of weight. You can also do the swap in a few days, not a few years. It would be just as easy of a spwap for the Fiero or a F-body but remember, RWD motors and FWD motors and not built the same way. As far as I know Fiero 2.8 heads will not bolt up to a RWD 2.8. It would be REALLY hard to swap a FWD motor into the Fiero, I know a guy that tried and gave up $5k later
David
thanks for the info i'll talk it over with my dad but i don't think he'll go for it he's had alot of bad experiences with swaps i still remeber he had this old '79dodge cargo van with a 318 4 speed the body was rusted to **** but he had some time and a 340 outta this 75 pickup so swaped engines except we had to have more power cause of our boat so it just started with headers then to edlebrock manifold the to the newest carb next the cam and lifters then heads the the gas shot up and off it went for 1000 bucks. so basicly just do the simple things and wait till i have alot of $$$ and time to do swaps
Originally posted by KED85
Send me an email & I'll give ya the facts, including about Fiero parts, too.
I won't answer anymore to this thread.
Originally posted by Ovrclck350
LOL, I don't blame you Ked. Half the time I can't understand what this guy is even trying to say, and the other half...I understand, I just have a hard time believing someone has enough of a lack of intelligence to say it.
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Okay the idea here is completely rediculous. If you want someting better in snow buy a cavalier or old corsica. Why spend weeks molding an area for this engine in the back when you could buy a winter beater for way less?
