Axel codes and ratios?
What ratio does code "G 92" stand for? This means "performance ratio", whatever one that is. Thanks. Also, what does "G80" stand for. Posi-traction?Thanks in advance!!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
G80 = Limited Slip Differential (posi)
G92 was used for a few different things over the years but most of the time GM used it for gear ratios of 3.08
You should have a RPO code for the specific ratio.
Damon
09-26-2015 04:29 PM
