Measuring Backlash?
Measuring Backlash?
I am installing an AAM rear end cover. The instructions say to measure backlash at 4 points on the ring gear before removing the diff in order to grind the oil return passages . I have never had a differential apart before. Where do I take the measurement from? I thought it should be directly from the face of the ring gear teeth. Would soumeone verify this or let me know if this is right? Thanks, Rob.
Car: 4
Engine: 6
Transmission: 5
The face of teeth, near the outer edge. You want to see how far the gear moves before the other side of the tooth contacts a pinion tooth. The reason you measure a few spots is in case the teeth don't all have the same clearance. Use a dial indicator stuck to the housing.
dimented24x7
09-17-2015 07:58 AM
