Change fluid
Change fluid
How can you get under the damn car? 89 gta is so low to the ground. Without a lift it's hard. I have rino ramps and can change oil but....stupid question anyways. I was running amsoil for 4 years and put 5k o. The car
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Re: Change fluid
Buy a low-profile floor jack and some jack stands at Harbor Freight. That's how I do it...
ughmas (09-10-2024)
Re: Change fluid
I have two approaches to this.
1: I bought two sets of ramps and had them made into a one set with a rather flat profile, so I can clear them with the from air dam and bumper. They have a jack at the end, so I can lift the car up to about 50cm above ground, I think.
2: Two jack stands plus a low profile movable jack which at least reaches the differential casing from the rear and is able to clear the hose pipe around the cat-area.
I could combine those and lift the car up evenly and securely that way.
Re: Change fluid
I have a longer nose low profile jack to lift my '84 T/A on the passenger side to get under the cat converter. I lift that side up just high enough to get another jack under the driver side. I do not use the "lift points on the rocker cover area as designated by GM. then jack each side as evenly as possible to lift the car until I can get two small jack stands under the engine cross member.
Re: Change fluid
Low profile or small jack that can reach the crossmember is key then jack stands. I installed UMI subframe connectors they also help with jack points.
ughmas (09-10-2024)
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Re: Change fluid
Drive the car onto a couple 1.5" X 10" boards first. Jack goes right under the crossmember then. Works the same for the diff.
Like this:
This works for me with Sportline springs and pretty bad ground clearance.
Like this:
ughmas (09-10-2024)
Re: Change fluid
That's what I did before getting my low-profile jack. 'Got tired of doing it that way, but it does work...
Engine: LT1, L98
Transmission: ZF6, ZF6
Axle/Gears: 3.45, 3.31
Re: Change fluid
Re: Change fluid
I start mine on some rhino ramps, then jack it up with a craftsman low profile floor jack. I don’t have the ground effects to deal with, but the jack won’t clear the air dam.
Last edited by KITT87; 09-10-2024 at 03:33 PM. Reason: Misread the OP and thought they were doing a trans fluid change
305q_ta86
05-13-2006 08:22 PM
