Will 9 bolt disc brake bracket and calipers fit to a 10 bolt?
I do have a 4th gen DB reared I can snag the parts from, but if the 9 bolt stuff will work, will make it easier on me.
thanks.
thanks.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Received 1,821 Likes
Re: Will 9 bolt disc brake bracket and calipers fit to a 10 bolt?
Everything but the backing plates. Those are unique to the 9-bolt.
The following 2 users liked this post by sofakingdom:
Mike Baggs (08-19-2024), T.L. (08-19-2024)
Engine: 4++,350 & 305 CIs
You can redrill and use them but definitely won't bolt right on.
Mike Baggs (08-20-2024)
looks like it was hit with a sawed off shotgun.
Some people worry about 1/2 a hole, never had an issue really. You can also slightly rotate the bracket and drill so you have all "new" holes.
keep in mind, you may need to to shim caliper to bracket or bracket to rearend. (I did for 9")
Thanks,
doesn’t seem like too much trouble, but no reason to worry about keeping the 4th gen rear intact.
thanks again.
thanks again.
subroc
Brakes
11-24-2008 03:49 PM
