TH350 swap
1 Post
Car: 1982 Z28 camaro
Engine: 5 litre
Transmission: 3 speed auto
TH350 swap
Hi guys
I’ve swapped out my TH200c for a TH350 trans in my 82 Z28. Do I need to swap the shift cable and shift brackets on the trans as it seems stiff trying to put it in park and the reverse lights are on when I put it in neutral.
The kick down works fine just seems like the actual trans shift doesn’t feel right.
Thanks in advance from Alan in the U.K.
Received 1,719 Likes
Re: TH350 swap
Sounds like a combination of the way the cable is routed, and/or its adjustment. AFAIK there's no need for a "different" cable.
The reverse light switch is on the shifter. Which if the cable is misadjusted, that's why it isn't properly synchronized with the transmission.
Re: TH350 swap
I put a th350 into a th200/crossfire trans am in the late 90s. We originally used the stock cable and had issues with alignment between shifter detents and gears. We ended up with an adjustable cable. I remember it being more frustrating than it should have been to get it aligned.
1 Post
Engine: 5 litre
Re: TH350 swap
I moved the bracket that’s attached to the trans that the cable sits in. I moved it forward about a quarter of an inch and that seems to have solved it. My shifter lines up with the indicator a lot better now and it all seems good. Thanks for asking.
8t2 z-chev (05-12-2024)
