Cannot remove diff cover
Car: 1985 IROC Z L69
Engine: LQ4
Axle/Gears: 3:73
I’ve tried everything I know. The last person used a ton of blue rtv on an aftermarket cover. I’ve tried tapping razor blades around the perimeter and scraping all excess off. I have the bearing cap stabilizer bolts really tight to help push out and the entire back of the car is jacked up slightly on the lip of the cover and it won’t budge. Heat gun did nothing. This damn cover is holding up the brake swap.
Any suggestions?
Any suggestions?
Engine: 4++,350 & 305 CIs
Re: Cannot remove diff cover
Deadblow hard plastic hammer.
chisel and reg hammer
Sure all the bolts are out?
Support the axle with jackstands and whack it with a soft face deadblow while prying.
Eroc85 (05-13-2023)
Carb cleaner sprayed slowly at the top of the diff cover so that it runs down each side and penetrates into where the razor blades cut the RTV. Give it a little time and the RTV will soften.
T.L. (05-14-2023)
I would use a putty knife and place it between cover and housing gently tap putty knife in between the two. work around the perimeter
T.L. (05-14-2023)
Car: 86 Camaro IROC
Transmission: stock autom.
Axle/Gears: stock
STOP please Stop !!!!!
Dont smash it up more and more
dont know how u name it in englisch but go and buy one of this windshield cutting out ropes / wires
you get the idea . lay it around the seal and cut your way trough it from 2 sides or 3
