Rear Dana 60 new ring and pinion
Hello everyone,
I am rebuilding my Dana 60 and setting up a new ring and pinion. Is this pattern acceptable? Let me know what you think.
Pinion preload used bearings for setup .019
No shims under pinion cup(from factory)
backlash is .010
backlash is .010
Re: Rear Dana 60 new ring and pinion
That's what I thought by your pics showing the rotated pattern. Looks like you're close on the drive side, I would check this pattern with the backlash on the tight side (0.005). Put pressure on the ring gear while turning the set for best readable pattern as possible.
You are definitely in the ballpark. Only fine tuning left going for perfection at this point. Good job!
NullHead
06-16-2014 07:16 PM
