Vette Torque Converter? and Gear?
Does a Corvette Torque Converter have a higher stock stall speed than a Firebird? If so how much higher?
Also are all rear gears interchangeable? Say I found a 88' V6 Firebird at a Junkyard and pulled the 3.42 gears, would they fit in my car w/o problems?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
There is a 2100 stall corvette converter
new s10's with 4.3 v6s has 2100 stall too.
If your rear differental is a 2xx series diff ypu would have to change it to a 3xx series posi for use a ring gear spacer
when installing 3.42's.
Asuming both are 7.5" 10bolts
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Vette Torque Converter? and Gear?
