Moser axle part #
Moser axle part #
Hey all,
Looks like it is time to RnR the axles , bearings and seals in the (stock)rear end on sons 89 formula he did have a good vibration at 60mph and above we got that fixed with a new 3inch diver shaft made by a custom shop near us.
I searched threads and dont see a part number for the moser axle and wheel studs in your rebuilds. I did see this for bearing and seals from James C which is a good write up
I purchased my Timkens from AutoZone. Double-check the following:
Wheel Bearing Rear, part #5707
Wheel Seal Rear, part #8660S
James C
Tim
James C
Tim
Re: Moser axle part #
Good question all we should've looked before posting we thought was a 10 bolt but its not it is a 9 bolt. Yeah we can look and net for #s but thought be easier see what you all use to make sure get right parts. This site has help us in the past with other mods to his car
Ok been searching around for the 9 bolt parts and found this on ebay. Anyone use them? If so pros and cons?
http://www.ebay.com/itm/USA-Standard...BWPYz0&vxp=mtr
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
moser doesnt make axles for 9 bolts.
I thought that Moser would make axles for anything. Anyway, there is almost never a need to replace the axles in a 9 bolt because the bearings are pressed on and don't cause wear on the axle it's self. A bent axle would be the only reason that I know of to replace one.
87_gta
06-11-2017 11:50 PM
martindforsythe
03-26-2016 10:19 AM
AmpleUnicorn88
02-25-2016 06:19 PM
Camarokid00
02-21-2016 09:00 PM
