Installing Drive shaft Firebird 3.1
Old 12-05-2015, 02:26 PM
czlowiekmucha's Avatar
Car: 1991
Engine: 3.1
Transmission: Automatic
I've replaced U-Joints and balanced the driveshaft, now it's time to install it.
But How?
Yoke is 98 mm wide and U-Joint is 92 mm wide, how to put it straight in line?
I think last U-joint was fitted exactly to the yoke, but maybe this is only my imagination...
I don't have the old U-joints I left them at the workshop.
Old 12-05-2015, 03:44 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Installing Drive shaft Firebird 3.1
The u-joint in the second photo should have come with four snap rings, yes?
Put the two extra ones on the cups for the differential yoke. The snap rings will allow the u-joint to center itself in the differential yoke.
http://www.driveshaftspecialist.com/...w%20Pinion.jpg
Old 12-05-2015, 04:07 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
the caps do not go all the way to the outside of the yoke, so the yoke should be wider than the joint ... or at least it looks like the old one did not go all the way to the ends anyway
Old 12-05-2015, 04:11 PM
Car: 1991
Engine: 3.1
They didn't gave me anything more in the workshop.
It is wider, so how to center it?
Old 12-05-2015, 04:26 PM
Barlow8869's Avatar
to center it, if you do not have clips, take some single strand 12 gauge wire and wrap it where the clips would go ... the clips/wire should not be there to take any stress, just to line it up ... or you could get 2 3mm washers and put one at each end while you clamp it on
ajk511
04-02-2007 09:55 PM
Thirdgeniroc
03-18-2003 05:50 AM
crazynights
02-20-2003 07:41 PM
MrJ
06-05-2002 11:33 AM
GTA88
11-30-2001 09:00 PM
Quick Reply: Installing Drive shaft Firebird 3.1
