1991 305 tbi trans into 90 iroc tpi
Old 11-30-2015 | 03:28 PM
sactown's Avatar
Wondering if there is anything I need to change I know the iroc has a 3.23 rear end gear ratio and tbis usually have a 2.7x would I need to swap anything from the original iroc trans to the tbi trans to make speedo and everything else work right? Thanks
Old 12-01-2015 | 11:55 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 1991 305 tbi trans into 90 iroc tpi
verify the rear gear ratio . then choose the speedo drive gear accordingly. you can swap the drive gears assuming you have two of the same transmissions
Old 12-01-2015 | 12:18 PM
sactown's Avatar
Cool thanks dont want to have to drop the trans twice thanks !!!
Old 12-10-2015 | 08:44 PM
AmpleUnicorn88's Avatar
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
Not sure about automatics but the manuals are interchangeable. Even with the V6 manuals. The rear gear ratio of 2 something is for the automatics on the 305 TBI so I'm assuming you are referring to an automatic. I believe the automatics were the same as far as size and bolt pattern for all 3 V8 options (305 TBI 305 TPI 350TPI) the gear ratios might be different internally for each one but they should still be a direct fit. If you are going from an auto to auto I don't think you have to change anything. Might have to change that sensor. I am not very knowledgeable on this, but I'm basing this off of stuff I have read other more experienced people on here have been saying for years. I would double check maybe even Google it to see if there is anything that is different as far as making it driveable and working correctly.
SnkSknrZ28
06-02-2016 12:40 PM
xbazzarex
Exterior Parts for Sale
11-14-2015 07:49 AM
Cleotiz
11-07-2015 07:11 AM
C-wade7
11-03-2015 01:10 PM
AmpleUnicorn88
Interior Parts Wanted
11-02-2015 09:33 PM
Quick Reply: 1991 305 tbi trans into 90 iroc tpi
