Rear Diff Question
Old 10-29-2015 | 08:01 AM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Rear Diff Question
Hi
I dissemble the rear diff to clean an painted for protection, it was getting surface rust.
First Question: Will it hurt anything if I pack with grease the axle Berings?
Second Q: What is the torque specs for the bolts that hold the axle in place?
I have a 1989 GTA
Old 10-29-2015 | 08:41 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Rear Diff Question
Assuming since it's an 89 GTA that you have the 9-bolt? if so, see post #3 of this thread for torque specs.
https://www.thirdgen.org/forums/faq-...now-about.html
I don't see why greasing the bearings would caust any problems, as long as you don't unseat something that needs to stay in a certain place.
Old 10-29-2015 | 08:44 AM
big gear head's Avatar
Those bearings run in gear oil, not grease. Just put some gear oil on them and put it back together. No grease.
Old 10-29-2015 | 08:50 AM
carattini's Avatar
Car: Pontiac 89 GTA
Thanks...
Old 10-29-2015 | 08:54 AM
carattini's Avatar
Car: Pontiac 89 GTA
What is the difference between these two?
Bearing Cap Bolts-Ft Lbs. 45
Axle Retainer Bolts-Ft Lbs. 36
Are't they the same bolts?
Old 10-29-2015 | 09:01 AM
Nope, not the same bolts. Bearing cap bolts are inside the housing holding the differential in.
Old 10-29-2015 | 01:55 PM
carattini's Avatar
Car: Pontiac 89 GTA
Thanks so then the bolts I'm talking about are the Axle Retainer Bolts-Ft Lbs. 36
Old 10-29-2015 | 01:56 PM
Yes.
Old 10-29-2015 | 02:12 PM
carattini's Avatar
Car: Pontiac 89 GTA
Will it hurt anithing if insted of 1.7Qt I put 2QT?.
Since it is off the car I have the ability to overfill.
Old 10-29-2015 | 02:21 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Do not overfill. The oil will just find its way out anyway & make a mess.
Old 10-29-2015 | 03:33 PM
It may leak. That rubber plug in the cover tends to leak anyway. I usually clean the cover and the plug well and then put a little RTV around the hole before I put the plug in.
STREETDEMON
LSX and LTX Parts
11-15-2015 01:30 AM
STREETDEMON
11-13-2015 03:22 PM
Piston454
10-23-2015 04:36 PM
nixonomics
10-22-2015 09:03 AM
ambainb
10-10-2015 09:19 PM
Quick Reply: Rear Diff Question
