Recommended fluid change for Differential??
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I know the diff is often neglected when it comes to fluid changes. How many miles should a car be driven before the fluid needs changed? Also I am replacing the pinion seal in my diff and am going to fill it with Moroso climbing gear lube is this alright to use??
I will be putting 75W/80W Red Line in my rear end sometime over the Christmas holiday.
Note that GM issued a TSB in Oct 1998 saying the the Brog Warner 9-Bolt should NOT get the posi additive.
maroe624
04-16-2017 08:29 AM
backtothe80s
09-05-2015 12:39 AM
Thornburg
08-25-2015 01:46 AM
92camaroJoe
08-13-2015 06:07 AM
