T56 Pilot Bearing Question
Old 08-29-2015 | 11:22 PM
TEEZER TA's Avatar
Car: 1986 Trans Am
Engine: 383 Stroker
Transmission: LT1 T-56
Been wanting to do a T56 swap for a long time and have been acquiring parts. One thing I did over look that I am not sure is if the crankshaft on my motor is machined to accept a pilot bearing? My motor is a pre 1986 383 stroker with a 2 piece rear main seal. I tried calling the shop that built it back in 2005 but they could not give me a definite answer. So my question is, do all aftermarket performance crankshafts drilled for a pilot bearing?
Old 08-30-2015 | 09:19 AM
Re: T56 Pilot Bearing Question
AFAIK yes they are.
Not hard to tell... the bearing/bushing (you could use either) is about 1-3/32" or thereabouts in diameter. If the crank has a hole that size and about ¾" deep, it's prepped.
Old 08-30-2015 | 10:07 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Never seen one that wasn't able to accept a pilot bearing
Old 08-30-2015 | 11:58 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Any SBC or BBC has it.
Old 08-30-2015 | 07:35 PM
TEEZER TA's Avatar
Car: 1986 Trans Am
Engine: 383 Stroker
Thanks for the information everyone! I did not want any surprises this winter when I pull the transmission to do the swap.
jharrison5
08-19-2015 06:53 PM
redmaroz
08-17-2015 12:40 AM
sreZ28
08-14-2015 08:48 PM
rsrmoore
08-07-2015 09:44 PM
