To wide strange S60
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
To wide strange S60
Hi!
Just got my S60 strange axle. Part Number: PRSF10
The axle match on bolts and springs but its to wide by 4" so the wheels are way out,i did not order any specific length,the only way to go now is a pair of 7"backspace wheels to compensate that or ?
Have anyone else order that axle,if so what was the total length of it.
Anders
Anders
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: To wide strange S60
Ok
What would you have done,new wheels ?
shorten it and get new axels ?
I wounder why strange didnt inform of that,they just say it fits 1982-02 f-body.
Have you called strange?
Engine: 383 HSR TPI
Axle/Gears: 4.10
Right now strange and summit are blaiming each other
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
Received 1,720 Likes
Sounds like you got the rear 4 a 4th gen F body. (93-02) Those are a bit under 4" longer than the 3rd gen, but otherwise identical.
It'll fit and work fine, if you use 4th gen wheels.
Give em a choice: either get you the right rear, or supply you a set of wheels. Ones of your choice, of course.
