S60 Rear
Car: 89 Camaro RS / 02 Silverado Z71
Engine: 1999 LS1
Transmission: 4L60e
Axle/Gears: 3.73 detroit truetrac
S60 Rear
Has anyone got the S60 rear from Third gen ranch. It seems like the best price from all my research. at just over 2300 its better the almost 3k for a 9in or 12 bolt.
Just wondering if anyone bought this rear and how it worked out for them. I need something soon before i break another 10 bolt.
thanks
thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: S60 Rear
There's a few members who have one but I think it's overkill for the majority of cars it's put in. It's heavy and eats the most amount of power compared to a 9" or 12 bolt.
My car survives very well with a 9" and aftermarket components are cheaper. Weight wise, with an aluminum case, daytona bearing support and spool, I can lift in the center section with one hand.
All 3 options have their positives and negatives. It depends how much you want to spend and exactly what you want under the car. Some people refuse to put a ford diff under their GM. That's up to them.
Engine: 1999 LS1
Transmission: 4L60e
Re: S60 Rear
I dont care to have a ford part under my car if it will make it stronger. I only expect to have around 400 rwhp now and i wouldnt think much more anytime soon. I need to be done dumping money into my car.
I have seen the 9 inch in places like moser, where are people buying theirs at, and what costs are we talking for something like that?
Engine: 1999 LS1
Transmission: 4L60e
Re: S60 Rear
I found a used 9in on craigslist from a 94 camaro. does anyone know how that would fit in my 89?
Car: 87 IROC L98
Re: S60 Rear
Technically if it will bolt into a fourth gen, it will bolt into a third gen. The only difference may be in the total width since fourth gen diffs are slightly wider.
Where to buy? Click on the web site banners and support the sponsors.
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Re: S60 Rear
The lightest of the three is the 12 bolt I believe and the most efficient given the size of the ring gear. It's a very tough unit. 400rwhp? No problem for this thing.
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Re: S60 Rear
Here is a good short write up CarCraft did comparing the 3 rears regarding the differneces in the HP/TQ...
http://www.carcraft.com/techarticles...o_results.html
Car: 87 IROC L98
Re: S60 Rear
So the dyno numbers say you'll have less than 10 HP difference between the 3 of them. Dragstrip numbers will differ greatly from what they claim. A lightweight 9" like mine will be quicker than a 12 bolt or D60 even though it eats slightly more HP. The advantage is in the reduced weight the engine has to move down the track.
For street use, the power difference between the diffs won't be noticed at all and heavy diffs add extra unsprung weight to a car. Unsprung weight is worse than sprung weight.
hectre13
12-11-2023 08:14 AM
1992 Trans Am
05-10-2023 07:19 PM
