strange s60 install questions
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am planning on installing a strange s60 rear end in my car this winter. I have a few questions if anyone here has installed one into their car.
1. They say that aftermarket torque arms may have to be modified. Is anyone here running a umi torque arm with this rear? If so how does it fit?
2. I plan on installing the chrome only pinion yoke and it says that the drive shaft needs to be shortened 2.125 inches. Can anyone confirm this length to be correct?
3. I will be leaving my 16" iroc rims on the car. Will the upgraded 1/2" wheel studs fit in the rims?
4. I am running the 98-02 ls 1 rear disc setup on my car. Will the axle come with brake lines set up for my brake set up?
Thanks for any help.
red90IROCls1
08-25-2015 06:56 AM
