T5 5th Gear Snapring Failure: What To Replace It With?
We are pretty sure the T5's 5th gear snapring failed. Question is: is there a beefier snapring we can replace it with?
Thanks!
Thanks!
Re: T5 5th Gear Snapring Failure: What To Replace It With?
One that's not been re-used in a rebuild (and stretched out by overzealous expanding plier use) is a good start. You don't want to expand them anymore than necessary to remove them from the shaft. It's easy to over-open them. Bending them closed again may work, but a new one is cheap.
As for your question, you're kind of on your own to zombie-glaze over parts listings of lock-rings that might work and be stronger.
I've added a groove to a mainshaft of a T56 (to copy a later-model lock-ring add) but the T5 5th gear lock-ring shouldn't be much of an issue.
Oh and it sounds like you're trolling for info without having opened up the transmission. So have at it.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Received 1,722 Likes
That snap ring doesn't just "fail". 99.9999% of all T-5s go to their grave with it intact. Out of the dozen or so cores I've had, and the dozens of times I had to rebuild mine before I finally wised up and got rid of it, I have NEVER seen any such thing. Granted, I'm not saying "it doesn't exist"; only, it must be pretty darned rare, and certainly not the first "explanation" that should come to mind, for whatever "symptom" that's being observed.
See my signature for a thought process that applies to such situations.![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
As jmd hinted at, somebody could conceivably have BROKE it by working on it improperly, unlikely though it may be; but as we all know, a human can break just about anything by doing something wrong. They're amazing that way, these humans.
A little history would help shed some light on this.
What is the car ACTUALLY DOING that makes you think that snap ring has "failed"?
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
I researched my car's symptoms and apparently 5th gear snaprings fail quite regularly in the T5. So I wanted to know if there are beefier snaprings out there to replace it with.
Of course if it turns out that's not the issue, we'll move to plan B.
Well I hate to bring this one back from the dead but I'm having this same issue. Driving home from work today, I was going up a pretty steep hill in my 91 Camaro and 5th gear just disappeared. It shifts into 5th but nothing happens. 1st-4th is fine and it still goes into reverse . I called Paul from 5speeds.com and he himself said that the 5th gear snap ring does and can come off. So yeah, I'd like some info on a beefier ring myself lol
Engine: 4++,350 & 305 CIs
Yup, back n the day I fixed waaaay to many T5s with the 5thgear clip broke or fallen off.
There is no need to power shift into 5th gear.. lol
I figured mine out. Here's a video I made.
https://youtu.be/CbbJn-AHLf4
Thank you.
