AWD? has anyone done this before?
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
Maybe its Stretch But I Think It Would Be Awesome To Convert My Iroc To AWD....Is This Possible And Has Anyone Done It? If So, Id Like To Know What They Did, What All They Had To swap Out, Etc. I Know It's One Hell Of A Project....
1 Post
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: AWD? has anyone done this before?
first thing that comes to mind is the astro van, some had awd and the 4.3 so any v-8 should work. dont know anything else though
1 Post
Car: 87 bird
Axle/Gears: 4.10
the trail blazer ss has it as well but second thought is the autotracs are kinda designed for snow and such so they engage when the rear starts slipping which wouldnt be good for a street car setup it would put a lot of stress on it. so you would have to figure out how to control it yourself so you can engage it before you hit the gas
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I think it's been done and there's a picture on the board somewhere. Looked like someone just got an AWD chassis and dropped the 3rd gen on it. Can't remember anything else about it.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
There are a few camaros near me that have been mounted on a blazer or S10 frame with the 4x4 drivetrain. Not really sure if that's what you're referring to, but it looks like hell IMHO.
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
I Don't Want It A Tall As A Pickup, I Want It To Look Normal. Someone Mentioned To Me Once That I Could Get A Frame From An Old comet But I'm sure There's More Out There That Could Be Fitted Somehow
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
Last post Was In Reply To The S10 Thing, Just Saw The Other Posts. Thanks, This Helps Out Guys
1 Post
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I thought about pushing the firewall back and putting a lamborghini V12 with the AWD transmission that bolts to the bottom of the V12 into my Z28, but the cost would be ridiculous.
Actually, extending the front chassis about a foot would give you enough room to run a transfer case, wouldn't it? You'd need custom fenders and hood to make it look right though.
1 Post
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Why not look into the chevy cyclone or typhoon (S10 based), The transfer case should hold up to the power
And yes you would have to redo your floor pan to make the transfer case fit, If I were to do something like this I would cut out the front frame rails , Floor pan and weld in a the front half frame and front diff suspension from a cyclone,but keep the stock rear half and suspension to your car or do a c4 corvette rear,
1 Post
Car: 87 bird
Axle/Gears: 4.10
thinking about it more you would have to do it that way your engine and frame are in the way. you would have to use the front frame and everything from the donor and i think it would end up a little taller.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
buy a 4x4 truck.... why in the world would you do that to a Camaro...
1 Post
Car: 87 bird
Axle/Gears: 4.10
if you could pull it off it could be really fast like a wrx but have street tires. you would surprise a lot of people on the street
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
GTR Real Expensive But A Sweet Car LoL If I Had Unlimited Funds I Would. Yeah I Don't Want 4X4, Like Jwfirebird Said It Would Be Fast...Think Of How Much quicker Since The Front Wheels Don't Have To Wait For A Push From The Rear, Takeoff Is Much Better. I Have Seen Pictures Of 4X4 Camaros Lifted, Looks Ridiculous
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Since the born of the GTR I've always had this crazy idea in my head that if I had money to throw away I would try to make a Third Gen a GTR would be just grate have the Wright technology with the Wright body
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
awd with a v8. no way to keep the camaro's stance low. front axle would be under oil pan(which is inches from the ground already). No room for that in a camaro. Maybe get a wrecked subaru that's been rear ended. Put the engine and everything in the camaro. Then you'd have an Jap powered camaro. That one movie Fast and Furious tokyo drift did something like that to that mustang
Car: 87 camaro
Transmission: th350
A cyclone sits low for a truck but would lift a camaro for sure. I dont think that would work. There to rare and expensive to cut up anyway
A Syclone isn't needed and other than the turbo specific stuff, isn't rare on a parts basis.
4x4 S10 has the same front end parts. The lower stance is probably just different torsion bars. The transfer case is AWD (from an Astro) versus the 4WD one from an S10.
Again, if you haven't checked out a 2WD S10 next to a 4WD S10 to see how much different they are, you need to.
1 Post
Car: 87 bird
Axle/Gears: 4.10
seems easier and tougher to use a full size front diff and tc and shafts, hubs. the ones ive seen on trailblazers and that are like a weird part of the engine. if you use the full size stuff you could sneek some room by offsetting it forward and setting the engine back
Car: 87 camaro
Transmission: th350
Car: 87 camaro
Transmission: th350
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
I have a typhoon I just looked under it and there is no way it would work and look good. The torsion bars go from control arms to behind the front seats. There is no room for the transfer case. So you would need most of the frame which is tall and would almost drag on the ground at stock height for a f body. I also have a Saturn vue awd that does not have a full frame which would fit under a f body then you can figure out how to get your engine sideways or do the 4 cyl turbo swap. The 3.5 Honda drive train that came in my vue has power you could turbo that or do the 4 cyl turbo swap some guys on here did.
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
yupp
well youre not in the states you can say that, do you know how hard it is to get any gtr in the states? even the new ones are expensive and pretty much a paperwork nightmare anything but the new ones a few r33s some of the rarer r32s are totally illegal anyway, that said it'd still be easier to get one then an awd 3rd gen, and why awd anyway? for better handling? let me tell you there isn't a whole lot out there with better handling then these (some) 30 year old cars especially if you do some susp mods
1 Post
Car: 87 bird
Axle/Gears: 4.10
modded wrx's ive seen at the track in the 10-11 second range are all on street tires. try to do that with rwd firebird, i suppose its possible but you would need very expensive suspension and the best drag radials. and on the street it would just blow off the tires
Your comment the Cyclone(sic) is too rare to cut up might lead one to believe it's a necessary donor and it's not.
And you can remove the idler gear from your **** anytime.
avro206
09-08-2002 12:34 AM
Hg
Theoretical and Street Racing
18
03-14-2002 09:58 PM
vortech305
07-31-2001 11:43 PM
