T56 from parts car, what to grab?
Car: 91 TA WS6
Transmission: Auto :(
I am going to pick up a T56 in a bit from an LT1 car a guy is parting out, what all should I be asking to get?
I have asked for the bellhousing, trans, pedals and shifter. Will I need the 4th gen drive shaft? I am coming from a 700R4.
Should I ask for the hydraulics - I know I should get new ones, but would they be useful for mockup?
Clutch is he has it in good shape? Will the LT1 flywheel work? Any wiring? Any stupid little parts that will be harder to source later?
Thanks guys. (And I did , but this just fell in my lap and I don't have hours to read through the many threads that have been posted)
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: T56 from parts car, what to grab?
everything related , don't forget clutch wires . you can always throw away what you don't need . can be hard finding bits & pieces , good luck .
The parts I would try to get would be
transmission
Bellhousing
All bolts!!!!!!!
Flywheel
clutch
ALL BOLTS
starter
hydraulics
Shifter boot that mounts to tunnel inside car
Pedals
T56 crossmember.......you can sell this to 4th Gen owners
Reinstall as was removed
transmission
Bellhousing
All bolts!!!!!!!
Flywheel
clutch
ALL BOLTS
starter
hydraulics
Pedals
Car: 91 TA WS6
Thanks for the quick reply guys. Unfortunately he had previously promised it to a friend who finally came up with the money just now, so it looks like my search will continue.
Car: 91 TA WS6
Lol, that wouldn't make it as good a deal. I'm also not real sure what all he still had.
https://www.thirdgen.org/forums/engi...-t56-swap.html
Car: 91 TA WS6
850 was the price, it sounded pretty good if I could have gotten almost everything I need. 92, I am consider yours, it's just a bit more then I was looking to spend at the moment. I would still require a driveshaft and cross member correct? Thanks.
1992 Trans Am
08-08-2015 08:16 PM
