t56 Transmission
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
t56 Transmission
Will the T56 transmission from the 1993 Camaros and up bolt up to a 350 for a 1984 camaro swap?
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Re: t56 Transmission
Im not sure, I havent gotten the engine yet, Right now I am doing all the research for the swap before I start buying the engine and transmission. what rear main seal does it need for the t56?
Received 1,837 Likes
Doesn't matter... you just gotta make sure you get the right T-56 flywheel (no other kind will work) to fit whichever motor.
If it's a 1-pc 350, then the stock T-56 flywheel will work. If it's a 2-pc 350, then you gotta get a $pecial "conver$ion" flywheel.
Hotrodboba400
12-10-2019 07:07 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
