700r4 speedometer gear ??
Car: 1986 Pontiac firebird formula
Engine: 383 sbc
Axle/Gears: 4th gen 3.42 posi
Hello everyone,
I have had my transmission rebuilt recently and its working perfectly, my concer is that my speedometer gear output gear is not spinning at all. I feel like the shaft gear is to far back on the shaft and is not aligning with the output gear. i know this because when i spin the drive shaft i get no movement with the key i stuck in there (key for electronic speedo sender)
is there something im missing? ive added photos for help
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 700r4 speedometer gear ??
Hello everyone,
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Axle/Gears: '01 3.42 10 bolt
The drive gear, red in your pics, is retained with a clip. There are 2 holes in the output shaft. It looks like the clip is in the forward hole, when you need the rearward hole. The driveshaft must come out, the torque arm must be unfastened from its bushing, the torque arm bushing bracket and transmission tailhousing must be removed, then you can correct this.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Possibly. Either way the fix is the same. I have 3 or 4 cracked plastic drive gears because they're a press-fit. Difficult to get them off without damage. Before installing the new one, boil it, wipe it dry, then wipe the inside with ATF. Then use a spare driveshaft yoke to help with pressing it on squarely. Once you bottom the yoke, a couple of bits of 2x4, cut from the same length to ensure same thickness, will help. Still use the yoke to press the 2x4s as they press the gear.
TheTraut88
09-07-2015 05:22 PM
