Gear pattern marking compound clean up?
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Got the gear pattern right on my 9-bolt rebuild. Does the marking compound need to be cleaned off or can it just get mixed into the oil?
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Re: Gear pattern marking compound clean up?
you can clean what you can..but dont worry if you mix it with ur gear oil..its designed for that..u used the correct marking compound?
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Yes. Got the yellow stuff from Ratech along with shims etc.
