tranny oil cooler size?
1 Post
Car: 1984 Chevrolet Camaro z28
Engine: 383 sbc
Axle/Gears: Stock...this is next
Hi Guys,
getting the car ready for the big motor swap. I've got my 383 built (lunati 60103 cam, Edelbrock Performer RPM heads and intake, 750 Holley Carb... stout enough street motor) Going with a 2400 rpm stall converter (suggested by lunati) and i'm running a rebuilt 700r4. I know I'll be heating up the trans fluid more than stock, so I came by a brand new oil cooler from GM at a reasonable price. the oil cooler is 7"x11"x1/2". Is this fairly standard? Do you think it will be good enough to cool the trans fluid for street and highway driving? It will be mounted to the front of the rad. Thanks, Ian
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: tranny oil cooler size?
It depends....
If it's a tube and fin, I'd say no. If it's a stacked plate, I'd say you're good. Is that last measurement really 1/2"? Most coolers tend to be 3/4" or 1.5 in terms of depth.
I'm running a 12 x 11 x 3/4" size stacked cooler. (Long Tru Cool #LPD4490) It's an excellent converter. Mine is bolted to the frame about an inch in front of the A/C condenser. I can just barely fit my finger between. The air gap is nice because it minimizes a hot spot on your cooler (from hot radiator) or your radiator (from hot cooler).
All transmission coolers are cheap mods. And worth every penny. Get a good one.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Stacked plate is more efficient than tube and fin design. Spend the extra money for a stacked plate style.
Tube and fin
Stacked plate
http://www.jegs.com/i/B-M/130/70264/10002/-1
Get a large cooler then run it inline with the factory cooler inside the rad.
Tube and fin
Stacked plate
Car: 1989 GTA
A stacked plate is like an A/C parallel flow condenser in the picture below. Much more surface getting cooled at any given time.
The multiple 180° bends on a tube & fin cooler create heat.
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
toronto formula
11-10-2015 06:17 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
Navy8125
08-21-2015 09:32 AM
