should i use a 700 or 400?
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Well I'm stumped on this one guys.
I recently did a 355 build.
My.machinist has made many builds like
This and says it'll.be making almost 400 hp.
Now im not sure wether to put my 700r4 back in
With a3500 stall or the th400 with a 4000 stall
And anti.balloon plate.
The 700r4 only.had 90000 miles and never slipped
And worked pretty good.
The th400 I.just got and it seems to be rebuilt as its got
New oil and front seal.
Still.have to make sure it works before any further plans though.
I kno the 700r4 is great for gas but the400 can handle the abuse for.sure.
I plan on using.the.car for.both street and strip. With a 100
Shot.
What I want to know is.if I'm.making atleast 300 to atleast
375 hp.at the wheel. Should I go with the th400 or stick.with
My 700.
I kno the 700 is great for.gas but I'm not concerened about
It since the motor will.hog has no matter what.
Would I be better.of spending the cash to put the 400 in my third gen,
Or just buying a converter for my 700 and going that route.
Shot.
My 700.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: should i use a 700 or 400?
How much highway driving do you plan on doing?
I think the 700 with the 3500 lockup stall sounds a heck of a lot more fun than a 400 with an unlocked 4000 stall. The unlocked stall on the 400 means you're actually going to be revving even higher than you normally would. And without an overdrive too.
There are ways to beef up a 700 transmission.
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
No highway driving at all. It'll.just be a car to cruise
And race at the strip
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Stall is related to the engine torque not the trans.
You don't mention camshaft or axle ratio which are factors in determining the required stall speed
Read
http://www.hardtail.com/techtips/sel...converter.html
Run too high a stall while cruzin and all you will be doing is generating heat from the convertor slippage
Read
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
A 3000 stall should be enough. Do you already know where to get the 400, they're getting hard to find.
Ok I see you already have the 400...
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
400....
Might as well, you'll probably want more than a 100 shot, especially if the engine combo is a dud unexpectedly.. fingers crossed,it isn't.
700 is strong and can be built well but it gets pricey.
Goodluck!
Goodluck!
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
400's are getting hard to find. I got mine for 60$! Hoping it works.
And yes hopefully its not a dud! If it is I won't be a happy camper!
400 it is then. Il just build the 700 for my dads truck build.
Engine: 4++,350 & 305 CIs
I'd do a well built 700R4
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Haha dang so may options! And opinions. Some say 400 some.say 700.
This is Whay me and my.dad keep arguing about.
Spend some bux building the 700 1 time and your done.
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
What year is your 700? 87 and earlier had some weak points iirc
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
My 700R4 is out of a 89.. I shredded the original many years ago because I was cheap. A well built 700 will be good. It is a matter of preference..
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
My original is an 85 so.its.the weak one.
It worked great for the 305 lol but that's a305
Mine is a 89 case with beast shell, billet parts, all the roller parts and 5pinion planets from a 2001 an up truck.. Lots of other stuff also.
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Will this will be fun. I mite as well build both. Sounds like.there both great
Transmissions!
Transmissions!
If you do a 400 talk with this guy.
http://www.morr-ink.com/Kilgore/Supe...uperlite_2.htm
If you are going to stay at 400crank hp , then the 700r4 will be fine.
If you are going to put some nitrous to it later on, then get the th400.
My 700r4 wouldv'e lasted me but I started putting 150+hp shot of nitrous to my 383 and the trans wouldnt last. The plus is the th400 is probably cheaper to rebuild than the 700r4 to hold the same power.
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
The thing is I still.have to.see if the th400 is in good working condition.
It's got a new front seal and its pretty clean.
But.you never kno!
But.you never kno!
If the trans is out of the car now, do yourself a favour and get it freshened up.
Its a pain the butt to put it in the car and then find out later that you have to remove it.
And if the th400 is completely stock, I would put better parts into it as well
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Well after.long thought I decided to put in th 400.
I wasn't sure if it would work so I said screw it. I put it in
And put it in drive the yoke moves and the tranny don't leak.
4 speed would've been great but. It was a 27 spline and the
Th400 is supposdly rebuilt.
All I.have to do know.is.get the trans mount with torque arm adapter
And a driveshaft.
I'm still debating though if I should get a longer drive shaft.
Or just take mine and get it worked on to hook.up to the
10 bolt rear and to.the th400 yoke
And a driveshaft.
88SS6SPEED
11-11-2015 07:05 AM
84 TA NV
09-06-2015 08:02 PM
