Turbo 350 short tail?
Car: 1991 Camaro
Engine: 355 5.7L
Transmission: Turbo 350
Axle/Gears: 373
I have a 350 backed up by a turbo 350 short tail in my 91 camaro. I was wondering if you guys had any advice about drive shafts from the 4th gens fitting in that application?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Turbo 350 short tail?
4th gen driveshaft is same length as a 3rd gen. You'll need to get a driveshaft thats made for the swap.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A driveshaft for an 82-83 third gen that came with the 200c 3 speed tranny will fit. That's your only option other than getting a longer one made.
Take you driveshaft into a shop that does driveline work and tell them you want it 3" longer. They'll but off the yokes and put a new longer tube in between them.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
For my th350 install, I got a kit that came with a longer output shaft and a spacer. Then the 700r4 tail housing will bolt up and you can connect the torque arm.
Street Lethal
04-30-2019 12:14 PM
theshackle
03-05-2017 06:37 PM
Eric-86sc
08-24-2015 09:01 PM
