Has Anyone Tried the 700R4 Close-Ratio Planet
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
......... I was wondering if anyone can verify / testify to any significant improvement in ET as a result of using the close ratio input planetary gear-set ... it changes 1st gear to 2.84 from 3.06 and 2nd gear to 1.55 from 1.63 ... sellers claims are a 0.3 - 0.5 second reduction in 1/4 mile ET's .........
Re: Has Anyone Tried the 700R4 Close-Ratio Planet
If your converter is sized right you wont be seeing those kind of gains. It will slip well above the rpm drop between gears and maintain powerband imo
It would be nice to have good gear spread but i dont see those et drops happening on a decent stall combination... Say 3500+ stall. i could be wrong but i have never had a problem with the 1-2 shift on my cars using 3200-3600 stall speeds. It be even less noticeable on higher stall speeds
It be similar to guys doin th350 swaps over 700r4 or even 200r4 swaps. I dont think i recall them having huge et drops like that but it really depends on the combination. 14 sec car vs 10 sec car etc
It also may be like gear swapped cars. I ran 4l60e to 12.31 at 109 with 2.73 and 3200 stall. Switched to 3.73 and that should have taken out some of the effects of gear ratio drop between 1st and 2nd but i only gained about 0.1, running lower 12.2's at 110. On side note with same street tires and same 60 fts, i gained 0.3 in 1/8 mile with just a 3200 stall over stock stall. 8.8 to 8.5's and then good tires hooked up bit better to give 8.2's. Then full drag radial and cold air i went 7.7's eventually
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I built that trans 3 years ago, and never installed it.
I plan to install it in the next couple of months, and run it when the track opens in March.
Sorry I cant be more helpful that that currently, but all I have now is an opinion of what I hope to gain, and another opinion of the gearset quality.
vrodpete@msn.com is my e-mail addy. Send me your e-mail, and I will update you when I can.
Car: '87 Vette C4
I am sure you saw my build up on the other forum.
Car: '87 Vette C4
..... I decided to go with a 4L60e and spent the money on a Rossler trans brake instead ... and a TCI/TCU to control it ..... Hey Pete ... did you get that trans on the track yet ?
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
