No clutch pedal after LT1 t56 swap, new slave and master...
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
I lost the clutch pedal a while back and replaced the slave because the push rod was bent. That did nothing even after a few attempts to bleed. Today I replaced the master but had to use an ls1 one, I've read that they are the same. I filled the new master up with fluid and attempted to get all bubbles out before putting the line in.
So I got under the car and pumped the **** out of the slave until I was told no more bubbles were coming out. I was told the bubbles started big and got small and the slave was definitely getting hard to push.
Now the other twist, my clutch pedal is no longer even with my brake pedal, is this because of the ls1 master? It was all the store had available and I need it running this weekend. The pedal doesn't seem to get harder to push after pumping and when the car is actually started the pedal gets even softer. With the clutch pedal pushed the car doesn't go into gear just kinda rolls.
Could there still be air, I'm trying to "gravity bleed" it now and I've heard the might vacs aren't real great for the lt1 clutches.
anyway heres some pics of the pedals and master alignment
the uneven pedals
the kinda uneven master alignment
and a shot of the clutch fork that I'm pretty sure is on the tob right?
tldr: new master and slave, old line, thought I bled it but still no pedal and no clutch to get it into gear, goes into gear fine without clutch. wtf is wrong?
the uneven pedals
1992 Trans Am
05-10-2023 07:19 PM
1992 Trans Am
08-08-2015 08:16 PM
rsrmoore
08-07-2015 08:44 PM
