Loud Banging!!! Need Help!!!
Car: 1987 Camaro Z-28
Engine: 383 Stroker
Transmission: t5
Axle/Gears: 3.73 gears
I have an 87 Z-28. has a 383 stroker in it and a T5 Transmission. I was driving just yesterday and this incredibly loud bang came from under the car around the transmission area. Happens sometimes when i push in the clutch to shift, even happens when im in gear, accerate then let off the gas it makes a loud bang.
I took a look underneath and tried to see if anything is loose.. only thing i noticed is a beam bolted to my differential that runs the length of my drive shaft is hanging free up by the tail of the bell housing. Dont know it is suppose to be like that but it appears to be fresh scraping marks on it. Could this be the problem? Does anyone jnow what they call that beam?
Engine: 383 Stroker
Transmission: t5
Re: Loud Banging!!! Need Help!!!
ok so that is it then ... took another look at it. the bracket busted off somehow... it is missing completely but both bolts are still attached to the bell housing missing from the arm though. thanks.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Now may be the time to look at aftermarket trans mounts, for example;http://www.umiperformance.com/catalo...roducts_id=298
Engine: 383 Stroker
Transmission: t5
thats a great idea... i dont have the funds to do that right now. is there a cheaper fix
for the moment?
i would like to do this though
for the moment?
UltRoadWarrior9
04-28-2020 10:39 PM
luvofjah
09-26-2015 08:28 PM
