T56/t5 flywheel question (yes I searched...)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
So, I have a 400SBC(auto) and I want to do the t56 conversion.
I have an aftermarket internally balanced crank, so I don't need a weighted flywheel.
Also, I already have the inline holes for a "normal" starter, so I can use a 153 tooth flywheel.
Here's my question, why do I need the centerforce flywheel? What's wrong with say, this one: http://www.summitracing.com/parts/NAL-14085720/
Also, would I need a different flywheel for a t5?
Last question, my 400 should be putting out about 380HP, and 480Ft-lbs of torque.
Do I really need a t56? Or would a t5 be okay? (not racing, so no power shifts...)
Thanks guys...
Thanks guys...
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: T56/t5 flywheel question (yes I searched...)
T5's die behind TBI 305's. You need a flywheel that will match your rear main seal.
Car: 87 T/A
I know I need a two-piece RMS. the one I linked to is two-piece...
Car: 87 T/A
Ok, I'm still confused, I can't see ANY difference between that one, and the one I posted, except for "preference" stuff, like weight, material, SFI rated, etc...
Why are the centerforce and fidenza ones "made for f-body 6-speeds?"
What makes them so special?
I don't give a hoot about the material, or SFI rating, etc... I just want the cheap one, why won't IT work?
Thanks...
Thanks...
Car: 87 T/A
Oh, and those two $450 flywheels are the only ones that match?
What's so special about the t56 clutch????
https://www.thirdgen.org/forums/tran...questions.html
Focus a little more on "how serviceable, reliable and well-matched can I make my powertrain" and a little less on "how inexpensively can I do this."
Car: 87 T/A
Gotcha, that makes sense.
So, question 2 then:
Those two flywheels are very different weights, I would LIKE to have the light aluminum one (I love that snappy quick-rev sound...), BUT, I don't want to have bogging problems etc.
I'm not racing, I just like to play around on the street so my "launch" matters to me ZERO. But I don't want it to feel like a small 4-banger either...
Since you have a similar weight flywheel, maybe you could tell me how it feels on the street?
Thanks.
Thanks.
Car: 87 T/A
Oh, and, I'm putting a low-end cam in it (lots of bottom-end torque), and it has a long stroke (400SBC), so I figure that would help with the tendency to "bog?"
Car: 1985 WS6 Trans Am T-Top
Engine: 355 TPI N/A
Transmission: Borg/Warner T-5
Axle/Gears: 3:42
I've driven an aluminum < 10lb flywheel with my T56, a 15lb one and a heavier aftermarket one (for 2pc seal) too. The < 10lb one is
choppier taking off from a stop than with a 16lb one. An ultra light flywheel is not going to benefit your type of use. And a heavy one won't help anything either.
The 15 or 16lb one was stock in a lot of third gens and works fine; no reason to go heavier or lighter.
Car: 87 T/A
It looks like the fidenza one (also cheaper), is around 13 pounds. I think I'll end up going with that one.
Now, I just need to FIND the t56 stuff cheap...
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
