Is this for T56 reverse lights?
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I bought a 89GTA that has a T56 in it. I'm getting ready to put the engine back in it and want to confirm this connector. The wiring isn't long enough to reach the reverse lights switch on the T56 so I wanted to confirm this was it before I cut the wires to lengthen them!
Car: 89 GTA
Axle/Gears: 4.10
Re: Is this for T56 reverse lights?
This connector is for the thing that mounts near the coil.... what is that thing?
Received 1,848 Likes
"Thing that mounts near the coil" is probably the EGR solenoid.
THat's not the reverse lights connector. Right style, right # of wires, but the wrong wires.
The right connector for that will have a blue and a green wire.
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Will the thirdgen reverse light connector mate into the t56? I have the green and blue wire connector that looks as described above, but havent run it into the tunnel yet.
