transmission whine
Old 04-08-2012 | 10:07 PM
m1doublet's Avatar
transmission whine
I have recently traded for a 86 camaro z28, 305 5-speed. Not sure what transmission it has from the factory.
It has a bad whine in low rpm acceleration, mainly in 3rd,4th,and 5th. If i shift to a lower gear and ride at higher rpm's it goes away. The previous owner put in a new centerforce clutch. Not sure if flywheel was resurfaced or new pressure plate or throw out bearing was installed.
Let me know what you think
Old 04-08-2012 | 10:51 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Re: transmission whine
You've probably got a non-world class t5 tranny. Unfortunatly, it sounds like you've got a bearing going out of the transmission and it may be getting ready to let loose.
Old 04-09-2012 | 11:21 AM
m1doublet's Avatar
If it was the throw-out bearing would it whine when the clutch is engaged???
only makes the noise when clutch is out and accelerating at low RPM's.
Old 04-09-2012 | 10:22 PM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
I would think that the throw out bearing would make noise when the clutch is pushed in (disengaged). That's when it has pressure on it. Unfortunatly the only definite answer will be when you take the tranny out and visually inspect everything. Good luck.
Old 04-10-2012 | 01:12 PM
m1doublet's Avatar
It only whines when accelerating in low rpm's after you let out the clutch. Which tells me the throw out bearing is fine. I just want to know what else it could be and/or how much whine is "normal".
Old 04-10-2012 | 06:27 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
As stated above it is probably a bearing inside the transmission that is going bad. The tranny you have is a factory T5 5 speed and it is known to be weak.
No real whine is normal in all the standard trans cars I have been in before. Never been in a T5 Camaro or Firebird though.
Hotrodboba400
12-10-2019 08:07 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 12:00 PM
TX-SleeperC5
09-24-2015 04:13 PM
Youngs92
09-23-2015 12:29 PM
Hotrodboba400
09-02-2015 08:28 PM
Quick Reply: transmission whine
