help please carrier problem
Car: 91 RS
Engine: 421 18 degree sbc.
Transmission: 2 speed glide from tci
Axle/Gears: 9" ford 5.29 gears
Ok so I'm installing my new gears and the bolt that holds the cross pin in the carrier broke off. Some of the bolt came out with threads on it but still some left in. What is a good way without destroying somethin to get that little pain in the *** out.
Thanks Cody
Thanks Cody
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: help please carrier problem
I don't have the link, but there is a kit available to.remove that broken bolt. Try a google.search maybe for cross shaft bolt extraction kit or something like that. I had to get one since I had the same problem last winter, and it worked like a charm. Its just a kit with a 12" flexiable drill bit, a drill. Guide for the bolt hole, and some screw extractors. Worked great, worth the cost of the kit which is breally not that much
1 Post
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
And the new bolt is available in the Help! section of most parts stores. Same bolt as the Mustangs too.
UltRoadWarrior9
09-02-2015 08:24 PM
