Yellow Speedo Gear for 91 700R4?
Old 01-27-2012 | 07:12 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
So i have 245/50/16 tires and swapped in a 3.45 9 bolt. Now i need speedo gears which I believe should be 15 tooth grey drive and 41 tooth yellow driven. I cant seem to find a yellow anywhere. and the one i do looks like this:
Problem is i need 1 that looks like this:
do they make it? does anyone know where i can get 1?
ALso do i need to change the speed sensor it self? Seems to be a difference on the speed sensor for driven gears over 40 teeth?
Old 01-27-2012 | 07:30 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Yellow Speedo Gear for 91 700R4?
gm 1362195 was the cable drive gm 25513048 witch is discontinued is the other one. Just buy a dakota digital SGi-5
Old 01-27-2012 | 07:39 PM
insomniac's Avatar
Engine: 5.7 L98
actually i think red 17 tooth drive ( which is stock on the car ) & 42 tooth light blue driven will work also. but now do i need to change the housing too?
Old 01-27-2012 | 07:47 PM
insomniac's Avatar
Engine: 5.7 L98
nevermind im an idiot it wont. damn
Old 01-27-2012 | 08:48 PM
Engine: Lb9
Transmission: M20
gm 10456088 or 10456089, standard motors sc12 34 to 39 tooth driven gear and sc13 40 to 45 tooth driven gear
jklein337
09-19-2018 07:23 PM
Eric2ndGen
11-05-2015 02:51 PM
stickychinsac
08-31-2015 07:06 AM
someone972
08-30-2015 01:52 AM
