Hawks T56 "double hump" crossmember fitment problems
I recently ordered a T56 crossmember from Hawks (double hump style) to replace my spohn crossmember. I can't get this thing to fit for the life of me. The spohn piece I have fits fine as I put it back in the car. Has anyone else had any problems with their Hawks crossmember not fitting? I talked to their tech support and they told me to make sure I had the right holes. So I went back out there just incase I did miss something, and sure enough, it will not fit. Has anyone else had this problem? It's almost like the crossmember is tweaked. If I sent it back and got a new one, do you think it would fit? Luck of the draw? Let me know.
Thanks,
Thanks,
ambainb
04-25-2016 09:21 PM
1991, 83, 91, body, camaro, crossmember, crossmembers, custom, double, fit, hawks, hump, humped, t56, transmission
