9 bolt worth it
9 bolt worth it
I have a 355 swapped into my 84 bird and I hear some noise that MIGHT be my rear end.
https://www.thirdgen.org/forums/tran...ml#post5153836
I am hoping my engine is producing around 350hp and similar Tq so I want a decent rear.
I have spent a while searching about different stronger rears. I am not ready to go 12 bolt or 9 inch, I do not plan on getting bigger tires or going to the track I am just looking to get some parts ready just in case mine has issues.
I have noticed some people seem to have trouble finding 9 bolt parts and posi cones. I think I found some on ebay
http://www.ebay.com.au/itm/Borgwarne...item43a2382821
and also at 9bolt.com.
In general it seems that parts are harder to find, but the rear is stronger.
There is a 3.23 posi 9bolt for sale local here for 200 OBO I was thinking of picking it up and swapping out my 10 bolt.
Is it worth it to get the 9 bolt for my 355 or should I just look for a 4th gen rear end?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 9 bolt worth it
A 4thy gen rear is no different than a late 3rd gen 10-bolt, except that it is wider & the limited slip in better, after 1998. 93-97 is the same axle, just wider.
4 pinion gears vs 2. Bolt in axles vs c-clips. I'd stay with the 89+ (biger b rakes) 9-bolt & just swap 98+ brakes onto it, if you need/want bigger brakes.
Re: 9 bolt worth it
Then later get 4thgen brakes for the 9 bolt? For now I was just planning on using my iron calipers until I could afford larger brakes.
Car: GTA
Re: 9 bolt worth it
Gotta think about your wheels too. Depending on what you have now, they may not fit. I tested mine on a 3rd gen with a 4th gen axle & it was out past the top of the fender, by over 1".
Re: 9 bolt worth it
OK I am going to go look at the 9 bolt. I am going to pull the back cover and check the cones. I was told it was a 3.27 anyone know the tooth count so I can double check?
Re: 9 bolt worth it
I would only go with a 9 bolt if that's what I had already.
When I did my rear end swap it was just the only thing I could finda t the time, and it had the 89-92 brakes which appealed to me quite a bit.
The posi cones available today will work but you need to have a machine shop modify the carrier or the cones themselves to make them fit.
The reason I think the 9-bolt isnt as good of an option as the 10-bolt is becuase replacement parts are too expensive. 9-bolts ARE stronger, but not by a huge margin. The difference is that if you blow up a 10-bolt there are used factory parts AND new aftermarket parts of everything inside a 10-bolt. You can put in a locker, a auburn clutch posi, a torsen posi, a huge variety of gear ratios used and new from a huge variety of vendors, and parts are common.
You blow up a 10-bolt and you can just replace what's broken with something from a junkyard. You blow up a 9-bolt and you may be out of anywhere from $200 to $700.
Re: 9 bolt worth it
So do you think it is worth it to go look at a $200 obo 40k mile one owner 9 bolt with a 3.27 and posi to have as a back up for my maybe dieing locking 3.73 10 bolt?
Car: 1987 Black IROC-Z (SOLD)
Re: 9 bolt worth it
Forget the wheel turing and counting gear teeth, just check the the stamped ratio on OD of the dr gear. All Mfgs stamp the ratiio on the dr gear OD.
Re: 9 bolt worth it
Thanks I will look when I check it out. I figure if the cones are good I can swap it in and figure out what I want to do with my 10 bolt. For 200 why not.\
Anyone else want to add?
UltRoadWarrior9
09-02-2015 08:24 PM
