T5 Flywheel on mild 350 - 16lb or 30lb
Old 01-23-2012, 01:27 PM
JP007's Avatar
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
I need to purchase a new flywheel for T5 that will be behind a 350.
Question is should I buy the lighter flywheel that Jegs has weight 16lbs or the 30lb Hayes? I see a 10lb flywheel the aluminum also. Street daily driver. I did not see this addressed in the FAQs.
Old 01-23-2012, 01:59 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: T5 Flywheel on mild 350 - 16lb or 30lb
I bought a Fidanza 10lb for a one piece rear main seal 350 from Amazon.com for $305.00 with free ship. Part #198531.
Hotrodboba400
12-10-2019 07:07 PM
Stangski09
11-14-2015 01:27 PM
Stryker412
09-07-2015 09:11 AM
willyjoejr
09-03-2015 09:26 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: T5 Flywheel on mild 350 - 16lb or 30lb
