banging noise from rear end?
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Just swapped my 10 bolt rear out for another used 10 bolt a few weeks ago. All has been good so far,but tonight i noticed a light banging noise from the rear right wheel. Feels like i am going over the same bump in a road over and over again. It is like a clunk,clunk,clunk. Car even feels like it is going up and down too,like going over a small bump. Only noticed the car do this one other time and it was when the temp outside dropped below 32 degrees just like tonight! Inspected rear gears and changed fluid prior to installing it. What could this be? It prob wont do it again for a long time or until temp outside drops really low again. Rear is not posi either.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: banging noise from rear end?
Start with checking the simple stuff. Lug nuts/LCA mounts bolts/shocks
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Go for a spin and try varying (slower) speeds to see if the noise picks up/slows down based on how fast you're going.
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
It's probably a wheel bearing or universal joint.
Received 1,753 Likes
Upper shock mount punched out of floor pan
Sway bar end link bracket bolts loose
1 Post
Axle/Gears: 3:42
I wonder if the 26 spline axles (v6 rear)i now have will hold up as well as my former 28 splines?
The top of the shock bolts to a stamped-out shape in the floor pan, right behind the rear seats. Very weak and prone to failure. Makes a weird noise when they punch out. Guess how I know....
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
My '91 TA also makes a "clunking" noise from the rear that I have never been able to isolate. It does not seem to affect performance but it is annoying. Mine shows up at low speed (5-20 mph) when I am trying to maintain low speed like in a parking lot. I have often thought is was just the way the posi rear acted since it has done this since it was new. Suggestions?
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Check your rear drum brake components, my brake shoe stabilizer bar came off and was riding on the brake drum surface.
Car: 1991 RS Camaro w/ Factory T-Tops
Engine: Built 355 ci SBC w/ Carb
Transmission: Borg Warner T-5
Axle/Gears: 4.10 with Posi-Trac
Engine: 4++,350 & 305 CIs
26-28 splines arn't the big problem, it's the weak diff and small gears.
1 Post
Axle/Gears: 3:42
its not posi,i just put in regular 80-90 gear oil in it. Funny thing is i just went outside to listen to it again and it doesnt seem like it can be heard when im in reverse.
Check the pinion nut to see if its tight. And make sure the pinion doesnt move in, out, up or down.. If its loose the head of the pinion head could be hitting the diff case.
1 Post
Axle/Gears: 3:42
I wonder why i cant hear it in reverse? and it only sounds like its coming from the right rear wheel too when going forwards?
When you rotate the rear backwards the ring gear pushes the pinion away from the diff. When it rotates 4ward the pinion is pulling itself into the diff. (I think, or its the other way around, Im old and 4getfull)
What did you have to do to fix?
But it sounds like the OP's issue might be something else, if it's something to do with just rotating things, not going over bumps and such.
1 Post
Axle/Gears: 3:42
UPDATE- the noise went away on its own today. the weather has warmed up outside though by about 20 degrees. ???
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
