top gear rpm at 60 mph with this combo...
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I was wondering at what speed my engine would be turning at 60 mph in 5th gear with a T5 tranny with a .73 overdrive gear with a 3.42 rear end. Would that combo still result in a car that will get reasonable mileage on the highway? That's what I'm thinking of using to replace the 700r4/2.73s my car has now.
Car: 88 Trans Am
Axle/Gears: Posi
Re: top gear rpm at 60 mph with this combo...
im not sure what my t5 5th gear is so im not sure how much help this is to you. but i have a 3.42 rear end.
2000rpm is 81mph on mine
60 would be about 1500
Engine: 4++,350 & 305 CIs
I guessed at your tire size with 26.5" somthing.. I used this http://www.wallaceracing.com/gear-speed.php
Engine Speed
(RPM) (MPH)
8000 RPM 253.58 MPH
7500 RPM 237.73 MPH
7000 RPM 221.88 MPH
6500 RPM 206.03 MPH
6000 RPM 190.18 MPH
5500 RPM 174.33 MPH
5000 RPM 158.49 MPH
4500 RPM 142.64 MPH
4000 RPM 126.79 MPH
3500 RPM 110.94 MPH
3000 RPM 95.09 MPH
2500 RPM 79.24 MPH
2000 RPM 63.39 MPH
1500 RPM 47.55 MPH
1000 RPM 31.70 MPH
Engine Speed
(RPM) (MPH)
8000 RPM 253.58 MPH
7500 RPM 237.73 MPH
7000 RPM 221.88 MPH
6500 RPM 206.03 MPH
6000 RPM 190.18 MPH
5500 RPM 174.33 MPH
5000 RPM 158.49 MPH
4500 RPM 142.64 MPH
4000 RPM 126.79 MPH
3500 RPM 110.94 MPH
3000 RPM 95.09 MPH
2500 RPM 79.24 MPH
2000 RPM 63.39 MPH
1500 RPM 47.55 MPH
1000 RPM 31.70 MPH
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Ended up doing this a long time ago when I wasn't sure that I either had or could get the right speedo gear... For a T-5 having a .76 5th gear, I run around 2036 RPM@60. Should be around 1950-2000 for you.
Engine: LB9
Engine Speed
(RPM) (MPH)
8000 RPM 253.58 MPH
7500 RPM 237.73 MPH
7000 RPM 221.88 MPH
6500 RPM 206.03 MPH
6000 RPM 190.18 MPH
5500 RPM 174.33 MPH
5000 RPM 158.49 MPH
4500 RPM 142.64 MPH
4000 RPM 126.79 MPH
3500 RPM 110.94 MPH
3000 RPM 95.09 MPH
2500 RPM 79.24 MPH
2000 RPM 63.39 MPH
1500 RPM 47.55 MPH
1000 RPM 31.70 MPH
Engine Speed
(RPM) (MPH)
8000 RPM 253.58 MPH
7500 RPM 237.73 MPH
7000 RPM 221.88 MPH
6500 RPM 206.03 MPH
6000 RPM 190.18 MPH
5500 RPM 174.33 MPH
5000 RPM 158.49 MPH
4500 RPM 142.64 MPH
4000 RPM 126.79 MPH
3500 RPM 110.94 MPH
3000 RPM 95.09 MPH
2500 RPM 79.24 MPH
2000 RPM 63.39 MPH
1500 RPM 47.55 MPH
1000 RPM 31.70 MPH
eightsixseven
08-14-2015 03:09 PM
