GM Factory Stall Speeds
Hello, I was wondering what stall speeds GM used in various vehicles that were equipped with the 700R4 transmission. I thought I remembered hearing somewhere that a 4WD S10 had a higher stall speed than our Camaros and Firebirds. Can anyone shed some light on this subject? Thanks everyone! ! !
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: GM Factory Stall Speeds
I doubt if there's any specific stall speeds listed anywhere. Stock converters stall somewhere in the 1500-1800 range.
Rated stall speed is only a guess. Stall speed depends on how much torque is put into it. A converter rated at 2400 stall may stall anywhere from 2200-2600. A converter designed for a V6 will stall higher when put behind a V8. A converter designed for a light vehicle will react a lot differently when used in a heavy vehicle.
If you want to try junkyard swapping converters, you're taking wild guesses at what may work or not and gambling that the converter isn't worn out or damaged. It's better to just buy a converter with a stall speed that matches the cam grind.
Thanks guys, thats all very useful information. I wasnt aware of the stickers on the torque converters. Maybe I can go to the junkyard this weekend and do some digging. LOCAL PULL-A-PART HERE I COME!!!!!
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
Eric-86sc
08-24-2015 09:01 PM
novaderrik
08-10-2015 12:44 PM
1992 Trans Am
08-08-2015 08:16 PM
