Whats the difference between a 93-97 t56 and a 98-02
1 Post
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
And what about t56's that were in corvettes, cobra mustangs, and vipers?
Re: Whats the difference between a 93-97 t56 and a 98-02
IIRC... LS1 (98-02) T56's have a longer input shaft. You may need a custom bell housing. At least thats what I have read...
LT1 (93-97) T56's have a shorter input shaft and most people here use them. The 94 and up transmissions have a different first gear and are rated for more torque (Am I correct, fellas?)
Im not familiar with the other ones...
1 Post
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
LT1 and LS1 T56's differ with the input shaft, mid plate and bell's, you can actually convert them vice versa. The gear box sells parts. i dont know about the others, im a GM guy.
1 Post
oh and corvette 6 speeds use a trans tube, cant use in stock form and too expensive to convert. (unless you WANT to dish out the dough)
1 Post
ok well I need a t56 for a 99 ls1 so I guess I'll just have to look for one off of a ls1
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i think the 1993 t56 has a lower sixth speed gear than the rest.
1 Post
You options are:
93-97 LT1 T56 (swap out bell, mid plate and input shaft)
98-02 LS1 T56
04-06 GTO MN12 6-speed (my recommendation, deeper gears, but pricey)
Vette LS1 6 speeds but the parts to swap out to convert make it not worth it.
I might be repeating myself up there but when i went looking, i had a hard time, my area was dry for T56's and so i opted for an MN12 at like double the price, and the month spent looking for one was frustrating.
You options are:
98-02 LS1 T56
98-02 LS1 T56
Just to the OP, be careful not to buy a 93 box; there's no LS1 length input with the right gear teeth, gear width and synchro compatibility to convert one to fit an LS1. 94-97 boxes are easy to change over.
RamIt (12-04-2022)
UltRoadWarrior9
09-02-2015 08:24 PM
